ArcGIS Pro 2 crashing opening 1.4 project
1276
07-07-2017 12:54 PM
deleted-user-m6DuRVNpNiGp
Hello --
So far I've tried to open two projects created using ArcGIS Pro 1.4 in ArcGIS Pro 2.0, and each time the application has crashed upon opening. I have been able to create a new blank project, but I obviously need to be able to open the existing projects. Thoughts?
 - geoff
Tags (3)
DanPatterson_Retired
Have you tried a 'repair' through windows add/remove programs?
When 2.0 was installed, were any other changes made?
Does the program work with a different user profile etc.
Thanks for the advice — I'm going to try the first two. Our IT folk did the install late Friday while I was working remotely, so it was hard to get much done befoer the end of the workday.
Dan,
Repairing fixed it. Thanks!
