ArcGIS Pro 2.8 fails to Clone Default Environment
5675
27
06-11-2021 12:00 PM
JoeBorgione
How do you know when I upgrade Pro to a new version?  I post a new thread on creating a clone...
I tried to clone the default to my 'clones' directory and that fails. I try to clone the default using the ArcGIS Pro path, and that fails.
I try to do a conda install in the default env of spyder and that fails
I try to do a pip install of spyder in the default env and that fails.
Oh my... This sounds more like a rant than a question...
Good thing it's Friday.
AshleyPattersonTheMapNERD
Having the same issues- Thanks for posting!
TGIF... AMIRITE
The Map NERD
JoeBorgione
Thanks @AshleyPattersonTheMapNERD ; while I'm sorry you are having the same problem I'm thankful it's not just me being a cement head...
That is a lovely mantra lol.  Thanks for taking me along on your troubleshooting journey - Have a great weekend!
The Map NERD
DanPatterson
Clean install from the *.msi after toasting all vestiges of esri folders, then start from there, is my usual 😉
... sort of retired...
JoeBorgione
So don't do an 'upgrade' but rather a complete install?
DanPatterson
That is what I do for every x.1 to x.2 .  House cleaning is good and it takes less time.  IF you have a laptop, you can even do it from a beverage patio on a Friday 😉
JoeBorgione
This is for my desktop at the office, so no patio beverages. (Although I am remotely logged in to it from home...   🍻
JoeBorgione
Sigh... After an uninstall and install of 2.8, same thing...
Have a nice weekend!
DanPatterson
cloning your clone won't work, you will need to update all your packages.  If you want to do this you should do this through conda.  You can create an environment with the packages you need and they will be up to date  (see conda create and create from a yaml )
Managing environments — conda 4.6.1 documentation
has lots of weekend reading.
