ArcGIS Pro 2.7 - Attempt to Publish to ArcGIS from Civil 3D fails
711
03-25-2021 07:11 AM
Linette
I tried to Output a Pressure Pipe Network and "Publish to ArcGIS" from Civil 3D, it did not work.  It got to the panel that allowed me to select Civil 3D elements, and I selected the Pipe Networks category.  The ArcGIS login screen did not appear afterwards.  Is there an extra extension that I am required to own?  I have the full ArcGIS Pro package and have Desktop installed...
Any suggestions?
Linette
Robert_LeClair
Esri Notable Contributor
If you're licensed for the Data Interoperability extension, you can import the AutoDesk AutoCAD Civil 3D file into ArcGIS Pro fairly easily.
