ArcGIS Pro 2.7.2: How to remove an environment in “the manager environments” of “python package manager” that’s labeled as “the environment can’t be r
2446
04-18-2021 12:14 AM
JamalNUMAN
Legendary Contributor
ArcGIS Pro 2.7.2: How to remove an environment in “the manager environments” of “python package manager” that’s labeled as “the environment can’t be removed, it is required for ArcGIS Pro.”,
I couldn’t figure out how to remove an environment in “the manager environments” of “python package manager” that’s labeled as “the environment can’t be removed, it is required for ArcGIS Pro.”.
Jamal Numan
Tim_McGinnes
Hi Jamal, The environment cannot be removed because it is currently active. You will need to make a different environment active by clicking the radio button in the Active column. When doing this, ArcGIS Pro will give a message: "Restart ArcGIS Pro for your environment changes to take effect.". Once you have restarted ArcGIS Pro, that original environment (arcgispro-py3-clone1) can be removed.
Tim_McGinnes
DanPatterson
MVP Esteemed Contributor
Activate the main environment (at the top), then you can remove a clone
... sort of retired...
JamalNUMAN
Many thanks guys. Setting another environment to be “active” enables deleting the target one
Jamal Numan
