ArcGIS Pro 2.6.3 Scheduler: Schedule a tool to run after another tool successfully runs
1432
12-09-2020 11:14 AM
RossCBrewer
New Contributor III
Using ArcGIS Pro 2.6.3's scheduler functionality, is it possible to schedule one tool to run immediately after a different tool successfully finishes?
*I'd prefer not to schedule these tools by time (seemingly the only option) because tool1 can take anywhere from 1 to 2 hours, and tool2 is deleting duplicate records from tool1, which could result in inaccurate data during the gap between the tools.
RobertKacir
New Contributor II
My recommended solution would be to create a model with both tools in it specifying the execution order. You can then schedule a single model instead of a two different tools. In model builder if the first tool fails, the second tool will not execute.
RobertKacir
New Contributor II
BenCoubrough
Hi @RossCBrewer I'd also recommend what Robert has suggested by using the ModelBuilder.
If you haven't built a model before you can follow this great tutorial which shows you how to build a geoprocessing model to automate a workflow.
Make a geoprocessing model - https://pro.arcgis.com/en/pro-app/get-started/make-a-geoprocessing-model.htm
Schedule a model - https://pro.arcgis.com/en/pro-app/help/analysis/geoprocessing/modelbuilder/scheduling-a-model-run.ht...
Schedule geoprocessing tools - https://pro.arcgis.com/en/pro-app/help/analysis/geoprocessing/basics/schedule-geoprocessing-tools.ht...
