ArcGIS Pro 2.5: What is the name of the tools by which panes are fixed according esri terminology?
I couldn’t figure how to call the tools by which the panes are fixed according esri terminology. How to call these symbols?
docking targets
Introducing ArcGIS Pro—ArcGIS Pro | Documentation
Drag the Catalog pane by its title bar over the map view.
As you drag the pane—represented by a blue shadow—docking targets appear in the center of the map view and at the edges of the application window. Each target represents an area where the pane can be positioned.
docking targets
Many thanks Dan
