ArcGIS Pro 2.5: Unchecking the “add to display” option for stand-alone tables outputs doesn’t remove them from the content pane,
1121
06-26-2020 10:37 PM
JamalNUMAN
Legendary Contributor
I observed that unchecking the “add to display” option for stand-alone tables outputs doesn’t remove them from the content pane.
In return, this works fine when it comes to checking\unchecking layers output. They are added and removed nicely
Is this a filed bug or by design?
Jamal Numan
DanPatterson
MVP Esteemed Contributor
The table isn't in the 'Display', so it doesn't remove it.  It is in the table of contents though
... sort of retired...
JamalNUMAN
Please, vote here:
ArcGIS Pro 2.5: Getting tables added to the content by the “add to display” option removed when unch...
Jamal Numan
JamalNUMAN
Solved here:
https://community.esri.com/t5/arcgis-pro-ideas/arcgis-pro-2-5-getting-tables-added-to-the-content/id...
Jamal Numan
