ArcGIS Pro 2.5: Publishing maps with ArcGIS Online option ends up with “basemap” error and “feature template set” warning,
I couldn’t figure out how to resolve the with “basemap” error and “feature template set” warning that come up when publishing with ArcGIS Online option
Solved! Go to Solution.
Hi Jamal,
You are encountering the error because you do not have a basemap. A basemap is required when sharing a web map. Inserting a basemap will resolve the error. Please see the following doc: 00216: Map does not contain a basemap—ArcGIS Pro | Documentation.
For the warning, see this: 24041: Layer does not have a feature template set—ArcGIS Pro | Documentation.
For future reference, you can open the associated help topic to the errors and warnings by right clicking on the message. A context menu will appear which provides a link to a help topic that describes the problem and lists available solutions.
Analyze your GIS resource—ArcGIS Pro | Documentation
Cheers,
Jonah
Hi Jamal,
Cheers,
Jonah
Hi Jonah,
Thank you for the help
Not user why these should be requirements for publishing! That doesn’t make sense for me. I assume that publishing needs to be straightforward with minimum prerequisites.
I got that using the “publish web layer” tool has less requirements and does the job perfectly
