ArcGIS Pro 2.5: How to show thousands separator on labels?
4861
10
02-28-2020 11:08 AM
JamalNUMAN
Legendary Contributor
I couldn’t figure out how to show thousands separator on labels. In ArcMap, the format of labels respects the format of values in the attribute table. This is sounds not to be applicable in Pro
Jamal Numan
DanPatterson_Retired
"{:,}  python format string syntax.  Other languages have there own
JamalNUMAN
Many thanks guys for the help
It works for me with the code below
text($feature.Female, '#,###')
Jamal Numan
AhmadSALEH1
You still can use the numbers formating  as the following, but don't forget to Save your edits to the fields
The result
JamalNUMAN
Many thanks Ahmad for the help
It appears that labeling doesn’t respect the format the values have in the table in case of Join!
What could be the issue here?
Jamal Numan
AhmadSALEH1
I am having the same behavior here.
The workaround is to add an expression
Arcade:
Round($feature.Shape_Area,2)
JamalNUMAN
Is this a bug or by design? I would appreciate if esri staff could help on this
Jamal Numan
JayJohnsonWashoeCounty
Ah, the old "invisible ellipses".  Thanks.
Jay
Washoe County GIS
JamalNUMAN
If the vbscript or jscript languages are used then the format in the table is reflected in the map label as shown in the screenshot below. This fails in case of python or arcade
Jamal Numan
