ArcGIS Pro 2.5: How to display the original reclassified values (start and end) along with the new?
1041
07-13-2020 12:46 PM
JamalNUMAN
Legendary Contributor
I couldn’t figure out how to display the original reclassified values (start and end) along with the new. This sort of presentation is quite essential as it reminds us what the values (1, 2,…,9) means
In addition to that, I’m not sure how these original reclassified values (start and end) can be linked to the polygon layer that is derived from the reclassify raster?
Jamal Numan
Robert_LeClair
Esri Esteemed Contributor
Jamal - to your first question about displaying Start-End Values in the Map View Contents Pane, I don't think this is possible with the GP tool.  BUT you can click the SAVE button below the NODATA line to save the column and values to a remap table.  Then you can add the remap table to your Map View and use that in your Layout legend once you convert the legend and table to graphics.  I haven't fine tuned my legend nor layout but you get the idea.
JamalNUMAN
Many thanks Robert for the help.
Nice workaround. However, I’ll be posting two ideas for this to have much more integrated piece of work
Jamal Numan
JamalNUMAN
Two ideas are posted
ArcGIS Pro 2.5: An option to display the original reclassified values (start and end) along with the...
ArcGIS Pro 2.5: Getting the “save remap table” option available in the “parameter” of the “reclassif...
Jamal Numan
