ArcGIS Pro 2.5 - Export Layout takes 20 Minutes
30804
29
02-27-2020 09:13 AM
by Anonymous User
Not applicable
Hello. Almost every time I export a layout in ArcGIS Pro 2.5, it takes 20 minutes. I tried turning on and off different layers, locking elements, exporting to my local drive, changing DPI, changing the file type, etc. I am not loading a lot of data. The "preparing to export" portion takes about 18 minutes and then the "export in progress" takes about 2 minutes. Is there a certain setting that I am missing? This did not happen with earlier versions of Pro. #arcgispro2.5 #export #slow #performance
by Anonymous User
Not applicable
UPDATE: I used the python window to export with this simple code...and it only took a few seconds!
aprx = arcpy.mp.ArcGISProject("CURRENT")
for lyt in aprx.listLayouts("Location"):
      lyt.exportToPNG("C:\\Users\\jsmucker\\Desktop\\Test2", 200)
Anyone know why the the python window would work this quickly, but not the tool?
ThomasColson
Works for me, but another odd issue here, is you have a DPI setting and I do not.....
by Anonymous User
Not applicable
That's weird! I wonder why...
KoryKramer
Esri Community Moderator
The difference is between exporting a Layout where there is an actual page size, and exporting a Map.
by Anonymous User
Not applicable
ThomasColson
Tech support would know the answer to this: "Anyone know why the the python window would work this quickly, but not the tool? "
MatthewGeorge
This worked great for me as a workaround but did you ever find out why there's such a huge difference?
A few things that we have found while troubleshooting is that if you have a new(ish) project (very little history) then the export would be consistently fast but if the project was older (had been used a lot) it would take longer more often than not. It was also noticeably worse when using Feature Services in comparison to direct database connections (SDE) to the same data. I contacted Esri Australia and got a bit of a run around so just told them to close the case.
JakubSisak
Honored Contributor
Excellent! Not sure why but I can confirm that using the python script takes seconds to export the layout.
StevenVanderploeg
This is the same issue for me.  I use Python to export any jpgs, pngs, pdfs, etc... from layout.  This is true for huge projects (aprx's, or maps) and for small ones.
LizNichols
Where is the python window?
