ArcGIS PRO 2.5.0 - Repair broken links for multiple layers Problem.
794
05-11-2020 03:59 AM
Rutenis
Hi, after ArcGIS Pro upgrade from 2.40 to 2.50 there was a problem with the update broken data links. Click the red exclamation point Repair Broken Data Source- changes only one layer (earlier to 2.4.0v changes multiple layers)
Maybe you can help solve the problem?
Thank You.
LukasFalk
Hello Rutenis,
Is the source data for the layers you're repairing located in the same place/gdb?  If so, then when repairing one of the broken links, it should automatically repair the others.  However if the source data for the layers you're repairing are in different locations respectively, you will have to repair each of the paths individually.
Consider the following example, you have 2 layers in a map with broken data links, LayerA and LayerB.  LayerA was added to the map from  DataA.gdb and LayerB was added from DataB.gdb.   When you repair LayerA, LayerB will remain broken because it came from a different geodatabase.  However if LayerB and LayerA were both in DataA.gdb, when repairing one, the other will repair as well.
Hopefully that clarified!
Rutenis
Hi, so all the layers are in the same *.gdb base, and before the update everything was fine
