Working with REVIT - the Draw time can be very time consuming, is this expected in all cases of Revit model size/data?
Are the additional tips for Optimizing Pro 2.2 environment. I have already gone through the ONLINE Docs. on display changes.
The Time is still very long, and how is caching working, bc It seems very negligible after a full load. Nothing seems to improve the time.
I realize the size of my models may have a lot, it is an entire building model, but just want to make sure I get all things that can be done to optimize the Environment. arcgispro #revit
From here
What is Revit data?—ArcGIS Pro | ArcGIS Desktop
ArcGIS Pro 2.2 supports Autodesk Revit 2015 through 2018 file formats (*.RVT) and converts Revit files to the 2018 file format as needed. If you experience slow loading times, consider preconverting the file to the 2018 format so ArcGIS Pro doesn't need to make this conversion.
And probably machine specs (video, video ram and ram)
Hello Todd,
Do you have access to Revit? If you have access you can do the following processes to improved performance
Process #1 Un-link or removed attachments
Process #2 Purge Unused (Families and Objects)
David
