ArcGIS Pro 2.1
875
11-06-2017 10:21 AM
RichardQuodomine1
Is anyone else having an issue with #ArcGISPro 2.1 transition from Gallery to Properties in Format Point Symbol / #Symbology - sometimes the screen blanks for a moment, and the response is slow. Screen Cap of location attached.
XanderBakker
Esri Esteemed Contributor
I don't see the screencap attached.
Are you working on ArcGIS Pro 2.1 (beta)? Shouldn't you be reporting any issues to the beta site?
RichardQuodomine1
Yes, I'm sure it's specifically ArcGIS Pro 2.1.0-beta.1 in the About section. I did actually attach the screencap, but it didn't take. I'll attach, thanks.
As for the beta site, I will also drop it in there, but as a developer item, I was wondering if anyone else had the same experience. My fault if it's misused here.
VinceAngelo
Please use an image format to share screen captures on GeoNet.  Word documents are a potential malware vector, and therefore much less likely to be downloaded/opened.
The beta license agreement usually stresses the use of a beta forum for questions and issues.
- V
RichardQuodomine1
Thank you, I have the original Graphic
