arcgis online turn off layer attribute column for viewing
680
07-01-2020 02:53 AM
Alexandra_Luisa_HøjgaardWood
New Contributor II
I'm not sure this is possible, but hopefully one oyu can help me.
I'm working on a project in which multiple layers have to be published on arcgis online.
A lot of our layers consist of attribute columns that shouldn't be visible once it goes online, but I would still like them to be a part of the attribute table.
Is there any function in which I, as the administrator, can turn on/off certain columns I want visible, or make some of the data/columns visible for certain invites?
I hope this question makes sense and that it can be solved.
Thank you very much,
Alex.
Egge-Jan_Pollé
MVP Regular Contributor
Hi Alexandra Luisa Højgaard Wood,
Yes, this is possible. Please have a look at this page:
Create hosted feature layer views—ArcGIS Online Help | Documentation
If you need a different view of the data represented by a hosted feature layer—for example, you want to apply different editor settings, styles or filters—create a hosted feature layer view of that hosted feature layer. Once you have a view, you can define which features or fields are available in the hosted feature layer view and share the view to groups whose members need access to that view of the data.
HTH,
Egge-Jan
