ArcGIS 3.0.2: What tool can select the records with the highest values in a particular field?
1782
13
01-15-2024 03:18 AM
JamalNUMAN
Legendary Contributor
For example, in the screenshot below, I couldn’t figure out which tool can select the FOUR records with the highest population size in the “population” field
Jamal Numan
Bud
Honored Contributor
I wonder if this would work in your model:
  1. Use the Sort geoprocessing tool to output a FC that is sorted by the population field (desc).
  2. Use Select By Attributes or a definition query to isolate the first 4 ObjectIDs.
Maybe that's the kind of thing @MErikReedAugusta had in mind in my ROW_NUMBER idea.
Somewhat related: Adding sequential numbers for the selected features
DuncanHornby
MVP Notable Contributor
I had considered that approach too as it works just as well, the only "issue" would be that sort creates an output table and the user would need to deal with that (i.e. keep it or delete it). If I had taken this route I would probably have written it to an in-memory workspace.
Anyway nice to have shown two solutions for the question!
JamalNUMAN
Many thanks guys for the help. It works fine
Jamal Numan
Bud
Honored Contributor
Top-n in primitive database (file geodatabase)
It's kind of brute force elimination and probably won't work right if there are rows with exact same value in population field.
population = (select max(population) from cities)
or population = (select max(population) from cities where population < (select max(population) from cities))
or population = (select max(population) from cities where population < (select max(population) from cities where population < (select max(population) from cities)))
or population = (select max(population) from cities where population < (select max(population) from cities where population < (select max(population) from cities where population < (select max(population) from cities))))
