ArcGIS 3.0.2: What is the equivalent tool to “import features” from geodatabase to feature dataset in the model builder?
420
05-04-2023 10:48 AM
JamalNUMAN
Legendary Contributor
As per the screenshot below, I need to import the feature classes from a particular geodatabase to a feature dataset. Which tool can perform this task in the model builder?
Jamal Numan
paudelsushil
You can use "Feature Class to Geodatabase" tools to copy feature classes from one feature datasets located in geodatabase to your desired geodatabase
JamalNUMAN
What I wanted here is to read the data from the source “file geodatabase” and then stick it “feature dataset”.
Then how to connect the source “file geodatabase” to the “feature dataset” having the source “file geodatabase” added to the model builder as per the screenshot below?
Jamal Numan
