ArcGIS 2.7.2: How to copy a folder in catalog?
1151
04-14-2021 01:13 AM
JamalNUMAN
Legendary Contributor
I couldn’t figure out how to copy folder in catalog. This option is used to be in ArcMap as per the screenshot below
Jamal Numan
DanPatterson
Copy and move items—ArcGIS Pro | Documentation is the recommended procedures.  Perhaps too many problems with shortcuts being used, it was removed.  Rename, New, Refresh and Copy Path are relatively save.  Paste is there when copied properly
... sort of retired...
JamalNUMAN
Appears not to work with me as per the screenshot below
Jamal Numan
Robert_LeClair
Esri Esteemed Contributor
In the current ArcGIS Pro (2.7.3), there is no way to do this.  There is an idea that's marked Under Consideration that you can upvote.  I suspect this will be available in a future release of ArcGIS Pro.
JamalNUMAN
Thank you for confirming that this functionality is not available.
I’ve already voted for the idea
Jamal Numan
