Arcade: Show names as labels if a condition is met
3895
10
01-31-2024 05:30 AM
Ed_
by MVP Regular Contributor
Based on the dummy data below how can I show only those values under `C1` as labels when let's say values of `C2` are greater than 40?
Sample data:
C1	C2
A	20
B	0
C	60
D	40
E	70
F	35
G	80
H	90
I	15
Question | Analyze | Visualize
Tags (3)
3 Solutions
KenBuja
MVP Esteemed Contributor
You can use this Expression
if ($feature.C2 > 40) return $feature.C1
ZachBodenner
Without too much trouble, actually! Depending on your environment, the actual locations of where you'd create the Arcade expression may change, but the basic formula is something like this:
var label = $feature.C1
var qual = $feature.C2
if (qual > 40){
return label}
else {
return
Happy mapping,
- Zach
KenBuja
You can accept more than one answer!
KenBuja
Ed_
Hi @KenBuja nice to hear from you, hope all is well, thank you for the super quick response 🙂. So I don't have to setup a variable first?
KenBuja
No, this shows the results of the one-line code. The two highlighted points show the Data field above and below 40
Ed_
Oh that's neat and super concise wish I could accept two answers lol
KenBuja
AlfredBaldenweck
if ($feature.C2 > 40){
    var lab = $feature.C1
} else {
    var lab = Null
return lab
The points are labelled with both C1 and C2 in red, and then this expression is for the black text.
Ed_
Hi @AlfredBaldenweck thank you for quick response, so in your code lab =  C1 then how come both C1 and C2 are being returned on the map?
AlfredBaldenweck
That's in a different label class for demonstration. The black text is what's being returned by this expression.
ZachBodenner
if (qual > 40){
return label}
else {
return
Happy mapping,
- Zach
