Arcade Label - Filter using a different layer
1438
7
05-05-2021 09:01 AM
RickeyFight
MVP Regular Contributor
I am trying to label streets on a map. I want only streets that are within a the polygon layer to display.
Is there a way to do this with arcade or is another way better?
jcarlson
var portal = Portal('https://www.arcgis.com');
var aoi = FeatureSetByPortalItem(portal, 'polygon_itemid', 0);
if(Intersects($feature, aoi)){
    return $feature.label_field
That might grab features that are along the edge or barely touch it. You could apply a negative buffer on the polygon, or change Intersects to Within, if you get too many "edge" features labelled.
- Josh Carlson
Kendall County GIS
RickeyFight
@jcarlson Thank you for the quick reply.
I am not using portal so I cannot use var portal.   Is there a way to identify another layer in pro arcade.
jcarlson
Try FeatureSetByName, maybe? That would look like this:
var aoi = FeatureSetByName($map, 'polygon_layername');
- Josh Carlson
Kendall County GIS
RickeyFight
@jcarlson
I am getting this error.
jcarlson
Oh, shoot. I forgot that using FeatureSetBy... functions is not available in the labeling Arcade profile. My mistake.
Everything else I can find will eliminate labels within a polygon, but not the inverse. Is the polygon layer something you can modify? If you turned it into a giant "donut", with the current shape being the "hole", you could use the Label Weight Ranking settings to exclude labels within that area.
- Josh Carlson
Kendall County GIS
RickeyFight
@jcarlson Yes I can modify the polygon layer. If I cannot find anything else I will try that. Thanks!
LindaWilliams1
Another way would be to clip your streets layer by your polygon, set this street symbol to no color, and then label this street layer rather than the one that extends beyond the polygon.
