arcade global to access in memory feature attribute
338
02-16-2022 09:29 AM
SarahHartholt
Can someone let me know which arcade global variable to use for accessing in memory features and attributes? I'm creating a model in ArcPro 10.9.0 that will select address points within a buffer poylgon that I have stored in memory. I would like to transfer a field from my buffer polygon to my address point field.
jcarlson
Can you add your expression to the post? If you have an in-memory feature, let's call it feat, accessing its attributes would be as simple as feat.attribute or feat["attribute"].
- Josh Carlson
Kendall County GIS
