Apportion Polygon - ERROR 002834: The geometry operation was cancelled.
2611
10-28-2021 12:40 PM
jblng
I am trying to use the Apportion Polygon tool to summarize the total square kilometers of crop land that falls in a series of travel time catchment area polygons.
My summary layer is a vectorized landcover crop mask. The target layer consists of travel time catchment area polygons (see screenshot - orange is input layer, blue is target layer). Both layers are in a file geodatabase, and I am only trying to summarize the AREA_GEO field into the target layer. After running for a couple of minutes, the tool failed with the following error messages:
Failed to execute (ApportionPolygon).
Alternative to this tool, I am open to using a combination of tools such as intersect and summarize within. My goal is to split the input polygons along the boundaries of the target polygons, and get the sum AREA_GEO field into the target polys.
Any help would be greatly appreciated!
JayantaPoddar
Please check if there are any geometry issues, and fix it, if any.
Checking and repairing geometries—ArcGIS Pro | Documentation
Think Location
DanPatterson
MVP Esteemed Contributor
To be sure, you should run
Multipart To Singlepart (Data Management)—ArcGIS Pro | Documentation
since some functions have issues with multipart geometry and do better with singlepart.
Then run a check geometry and repair if needed
... sort of retired...
