Apply same graduate colors symbology
207
01-02-2022 02:53 AM
SalahAjjur
I have 7 layers containing points features, each in a separate Map. Each layer has its own limits (max and min values). For example, values range from 32 to 38 in layer1, from 35 to 40 in layer2, etc. I want to apply a standard graduate color symbology to all layers, so it starts from the min value and finishes by the max value in all layers (let's say from 32 to 40 as per the above example). The standard symbology will also exclude a point. Can you help me?
Salah
SalahAjjur
In case someone faced the same issue, I solved it by
1- create a layer that had the maximum and minimum points
2- apply a standard graduate color symbology to this layer (you can exclude some points)
3- Copy the layer to all maps and use the "import symbology" option (maintain ranges).
Best,
Salah
SalahAjjur
Can save the symbology style solve this problem? How?
SalahAjjur
Best,
Salah
