Adjusting Units of a scale bar with arcpy
1222
11-20-2023 12:56 PM
StevenTouzel
I'm using ArcGIS Pro 3.2 and I'm trying to use arcpy.mp and the layout CIM to update a scale bar's units.
This is what I have so far, but the units somehow get erased from the layout cim json instead of updated:
import arcpy
aprx = arcpy.mp.ArcGISProject("CURRENT")
vicinityLayout = aprx.listLayouts("Fig1_Vicinity")[0]
# Update scale bar units to miles
scaleBarName = 'Scale Bar'
vicinityLayoutCIM = vicinityLayout.getDefinition("V3") # Get the layout CIM
## Find the Scale Bar - updating the units for the
jsonText = "{\"uwkid\":9093}"
for elm in vicinityLayoutCIM.elements:
	if elm.name == "Scale Bar":
		elm.unitLabel = "Miles"
		elm.numberFormat.roundingValue = 0
		elm.units = jsonText
vicinityLayout.setDefinition(vicinityLayoutCIM)
StevenTouzel
Found the solution. I needed to convert the unit string to json. Not just make it look like json. This worked!
import arcpy, json
jsonText = "{\"uwkid\":9093}" # need to convert this to json to make the unit update
scalebarUnit = json.loads(jsonText)
		elm.units = scalebarUnit
StevenTouzel
import arcpy, json
cquick2
Thanks a lot for this. For those, like me, who are not familiar with uwkid 9093 meaning 'Miles', this is documented here: LinearUnit Class—ArcGIS Pro
