Address locator takes 20x longer to rebuild in Pro 3.3 than 3.0... why?
1691
12
11-26-2024 09:27 AM
AllenDailey1
I've discovered that, since upgrading to Pro 3.3.2 from 3.0.3, rebuilding address locators takes about 20 minutes, whereas before, it took about 1 minute.
This is the case both with a Python script and when doing it manually.  It even happens when rebuilding an address locator I created from scratch in Pro 3.3.2 (as opposed to the existing locators I had made with Pro 3.0.3).
This worries me because I'm wondering if it means something is wrong...?
Does anyone know why this is happening?  Has anyone else experienced this behavior?
Thank you!
Allen
ShanaBritt
@JoeHeggenstaller Keep an eye out for the 3.3.6 patch, which has a fix to this behavior if you are unable to upgrade to 3.4.
JoeHeggenstaller
Sorry @ShanaBritt I forgot to reply a few weeks ago.
I just tested rebuilding a point file locator using Pro 3.5.2 and it only took about 25 seconds, which from my past experience in ArcMap and earlier versions of Pro seems about right for our 110,000+ address point file.
ShanaBritt
Thanks for the update @JoeHeggenstaller !
