Add Join not keeping all target features
12247
16
10-25-2023 08:54 AM
YusefSamari
I am trying to join a table to a feature class using the Add Join tool. The box 'Keep All Target Features' is ticked:
Based on my previous experience, and the info on the pop-up box of that parameter, this should mean that all features in the input layer are kept, regardless of whether the join fields match. However, the resulting output is only including input features that match on the join table field, regardless of whether the box is ticked. Basically it seems stuck on performing an inner join even though an outer join is selected. This happens regardless of whether or not the fields are indexed. Both the feature class and the table are stored in a geodatabase.
Please can anyone advise as to why this might be happening?
ChristineSeidel
Yep, had the same issue trying to join a Table to a feature class (both stored in the same file geodatabase).  The feature class had a definition query and 'keep all input records' was not honored.  So, I exported the filtered feature class to a Table.  Then established the join from Table to Table (neither having a definition query) and then finally the 'keep all input records' when joining was a success!  ...though quite a nuisance of a work around to generate extra tables just to find the misfits.
Bud
Legendary Contributor
ArcGIS Pro 3.2.2; File Geodatabase
To build on the comments about definition queries and joining:
When joining from table A to B, if B has a definition query prior to the join (such as TYPE=100), then the definition query will be applied to A (joined to B); I'll call it AB.
If B.TYPE has rows where TYPE is not 100, then the definition query will exclude those rows in AB.
Video:
(view in My Videos)
That can be confusing because the user might have considered the definition query to only apply to B. But in the AB join, the definition query applies to the entire query.
If we look at the Diagnostic Monitor tool, we can see that ArcGIS Pro has sent this SQL query to the database (the SQL formatting is mine):
SELECT
    OBJECTID,
    Shape,
    Shape_Length,
    Shape_Area,
    ID,
    OBJECTID,
    Shape_Length,
    Shape_Area,
    ID,
    TYPE
FROM
    A
LEFT OUTER JOIN
    B
    ON ID=ID
WHERE
    TYPE= 100
That WHERE clause applies to the entire query.
If we want to include all the rows from A, regardless if there is a match in B, and if we want to keep the definition query, then we'd need to add OR B.TYPE IS NULL to the definition query.
B.TYPE = 100 OR B.TYPE IS NULL
But I'm not an expert. Maybe @JonathanNeal@JoshuaBixby@MarceloMarques, or @AJR could weigh in or at least find this interesting.
There is a technical article or bug report somewhere about this topic that suggests the  OR B.TYPE IS NULL  workaround. But I can't find it right now.
I wonder if there are any other attribute filters, other than definition queries, such as time filters, range filters, or selection layers (selection definition set) that might have similar quirks? I haven't wrapped my head around that yet.
Bud
I'm starting to second-guess this comment. Testing ongoing.
When I think about this more, my definition query that has OR TYPE IS NULL is kind of useless. It doesn't do anything; it doesn't pare down the rows in B.
So maybe a different approach is needed. Either get rid of the definition query, or, if B does need to be pared down where TYPE=100, then maybe that should be done some other way, prior to the join.
Options for pre-filtering:
  1. Query Layer (enterprise geodatabase only)
  2. Database View
  3. Export (using a definition query or selection) to a static copy, as @ChristineSeidel suggested
  4. Make Query Table, since it doesn't put its SQL expression in a definition query, it hides the SQL expression, unlike Make Table View and Make Feature Layer.
    1. See the list of options in this post: Consistent/visible SQL expressions and query definitions in layers
Here's the result when using Make Query Table to pre-filter B before joining. It seems to work:
The downside is that the SQL expression is hidden. As far as I can tell, it is only visible via code, such as saving the layer as a .LYRX and then viewing the JSON in a text editor. So, users would have no way of knowing that the table is being pared down. The best we can do is put something in the layer name, such as "B_QueryTable_Filtered".
Edit: It turns out there is an existing bug report that also suggests the Make Table workaround:
Or, do the join in a full-blown SQL query (database view or query layer) instead of doing the join in Pro via Add Join. The downside is that it's not possible to edit the data in a database view or query layer.
The SQL query might look like this:
select
    a.id,
    b.id,
    b.type
from
    a
left join
    (select * from b where type=100) b
    on a.id=b.id
or
--tested in Oracle 18c
select a.id, b.id, b.type from a left join b on a.id=b.id and type=100
There are likely other ways to do it in SQL, such as using the WITH clause (aka common table expression) in enterprise and mobile geodatabases to pre-filter B.
Idea: Add Join — Indicate that a definition query on join table will effectively result in an inner join
Bud
JoshuaBixby
MVP Esteemed Contributor
Doing some basic checks/testing in Pro 3.2.2 with file geodatabase feature classes and tables, I see the expected behavior and not this behavior.  Can you provide more information about the tables involved.  Are they both in the same workspace?  Is that a file geodatabase, mobile geodatabase, geopackage, etc...?  If they are in different workspaces, what are those?
Also, what version of Pro are you using?
justin-mpls
Just wanted to share my experience with this problem as well.  This is on ArcGIS Pro 3.1.3, attempting to join two feature classes within the same file geodatabase.  I was trying to join a feature class of ~500 records to one with about 78,000 records and got only 88 matches when I should have got close to 78,000 matches.  The key fields were indexed on both sides.  First I tried eliminating all null values from the key fields in both tables and this made no difference.  Then I checked using Python to make sure the target table key values were a superset of the join table keys (they were).  Finally, I stumbled upon this thread (and this one https://community.esri.com/t5/arcgis-pro-questions/add-join-not-working/td-p/1142660) and deleted and rebuilt the attribute indexes for the join fields, which finally solved the problem.
@Robert_LeClair
The tool help says "If the join results are unexpected or incomplete, review whether the Join Table Field and Input Join Field parameter values are indexed. If they're not, try deleting and re-creating the index and rerun the tool."  Because I had already indexed the fields, I didn't think this would be the problem.  The help should be more clear that recreating an existing index may be necessary.
It would be very helpful to document this problem and solution on one of the knowledge base pages for join issues, such as this one:
https://support.esri.com/en-us/knowledge-base/problem-joining-two-fields-does-not-return-any-matchin...
Thanks.
Robert_LeClair
Esri Esteemed Contributor
With regard to documenting this problem and providing a solution, likely this would need to be created by Esri Support Services staff.  I did a cursory search of existing Knowledge Base articles and did not find any with search terms of index create join -  With regard to the tool help page item - if you go to the bottom right of the webpage, there is a button click - "Feedback on this topic" one can provide feedback to the help authors to investigate and improve.
Lastly and maybe related, there is BUG-000128476 -  Creating a join does not work if the key field’s type is a short integer.  Not sure if this is related to what the OP is experiencing.
