Add Folder in Catalog pane starts, but crashes ArcGIS Pro while loading.
1358
20
02-28-2022 10:45 AM
RalphAnhold1
New install of ArcGIS Pro, Windows 11.  Start project with blank template.  Want to add existing folder, so in Catalog pane/folders, I right-click, select AddFolder.  UI pane starts, but update stops and Error reporting tool pops up.  No recovery.  It 'appears' that I can't use existing data.
Hints on how to fix?
ABishop
MVP Regular Contributor
Hello Ralph,
To troubleshoot, do the following:
Click on this link:  https://pro.arcgis.com/en/pro-app/latest/get-started/arcgis-pro-system-requirements.htm
Choose your version of ArcGIS Pro.
Then click on the link right after the opening paragraph that says "Check your computer's ability to run ArcGIS Pro 2.x"
This will give you an indication if you have all the right components installed on your PC.  If it turns out that you do, you may want to repair ArcGIS Pro by reinstalling it and choosing "Repair" during the installation process.
Hope this helps.
Amanda Bishop, GISP
RalphAnhold1
Thanks Amanda!
Followed your recommendation.  Computer's quals checked out OK.  Ran repair install.  Still didn't work.  I then tried another operation.  As soon as file dialog opened, ArcGIS crashed.  That gave me another clue, but I dont know enough to diagnose.
ABishop
Hmmmm.... what else did you try and what dialog appears?
Amanda Bishop, GISP
RalphAnhold1
I opened a geoprocessing tool, and attempted to define an input filename. As soon as the dialog came up, bang. Pro halted, the error reporting tool came up, and I used Windows Task manager to kill the stalled process.
ABishop
What type of file is it?  Where is it stored?
Amanda Bishop, GISP
RalphAnhold1
Actually doesn't matter, the dialog crashed things before I could select.  It would have been an old shapefile.  But I couldn't even start navigating in the dialog.
-r
ABishop
What version of ArcGIS Pro?
Amanda Bishop, GISP
RalphAnhold1
2.9.1
ABishop
Have you removed all old version of desktop from your machine?
Amanda Bishop, GISP
