Add data from A to Z to the Map Contents turns from Z to A Question
878
03-03-2022 04:49 PM
PROBERT68
Honored Contributor
So when you add a lot of layers or imagery that you need to add to Map, so when you use  your mouse and use the shift to select multiple layers or photos.
Whenever I tried to start with Ascending and add them to Map, it doesn't ascend correctly.
When you the Add data, and you start to select from A to Z to the Map, the Layers would start from Z to A
Why does it do that ?
P.S. As of March 5, 20222 Finally got it up and running . Actually , was going to upload here, however, I could not for some reason...Found a way around to get it here...
https://drive.google.com/file/d/18QgnW-ALbXQiULQM6fS5zLJ9arVRSOri/view?usp=sharing
When you open it,  Be sure to change the Quality set to 1080 HD.  You will see better.  There is no audio at all . But I have a notepad open so Enjoy !
Thanks !
PROBERT68
Honored Contributor
So no one respond and thank you for that... I finally figured it out how to get them the sort in order from A to Z.
PROBERT68
Honored Contributor
I'll upload the video....
PROBERT68
Honored Contributor
I'm trying to upload my video and it is only 42 MB and won't let me to.  Any reason for that ?
PROBERT68
Honored Contributor
