Accessibility of Sub-Layers in Contents Pane
481
10-18-2022 10:26 AM
milleka2
Layers are more often than not symbolized on an attribute or multiple attributes. It seems as though it would be efficient to be able to access (Select) the highlighted layer sub-classes in the Contents Pane, rather than repeating this filtering task with a definition query, or selection by attribute. Does anyone now if this is possible? I do see that the Scales tab has the option to show the number of records in each subclass...
