Hi!
(Beginner Level) I´d like to create an interactive map using ArcGIS Pro (ver 2.8) that shows certain points of interest (POIs)/features within a "15-minute-walking radius". I figured that might work if I created a buffer around certain points on the map to mark all POIs within that radius and translated those steps into a workflow.
Is it possible to create a buffer around any given point on the map? Or are there smarter ways to go about this?
(I apologize for any grammatical errors on my part, as englisch isn´t my first language)
Solved! Go to Solution.
Sure, just use the buffer tool with an input of your points Buffer (Analysis)—ArcGIS Pro | Documentation
There is also network analyst Create Drive-Time Areas—ArcGIS Online Help | Documentation
Thank you!
