When using TAB to jump between properties - select all in next numbers box
313
06-16-2024 05:04 PM
Status: Open
RTPL_AU
Replicate default behaviour in many other applications and select all the text in a settings box when using TAB to jump between fields.
Pro currently just jumps to the front of the first digit in the next box. Text item location is a good example where you may want to type in the X location, press TAB, then type in the Y location.
