Currently, if you have data driven pages enabled and you need to slightly modify the page layout (pan or zoom), the export map function won't honor the page layout changes you have made. Rather, it defaults back to the shape and extent of the current data driven page that you are on. This is most likely by design but there should be a check box in the Export Map command to override the data driven pages and export out what's currently on the page layout.
This is available with when exporting a map series in ArcGIS Pro.
