Vary symbology by attribute - Rotation - does not use Pro's Angular Units and Direction Units which is a surprise. So simple idea:
Please implement Vary symbology by attribute - Rotation to consider angular and Direction Units.
Now this is easily fixed with Arcade (at least in my case with degree to gon conversion) but it feels strange having to do this with Arcade as long as project settings are carefully worked out (angular unit set to gon, direction unit set to North azimuth with gon as direction base unit)
