Use Default Coordinate System in Geoprocessing Tools
439
03-21-2019 11:08 AM
Status: Open
JakubSisak
Occasional Contributor III
Coordinate System in Geoprocessing tools defaults to WGS_1984_Web.  It would be beneficial if it was automatically set to the Map Application Spatial Reference default (as set in Options) instead.
1 Comment
KoryKramer
Jakub Sisak‌ The description is about geoprocessing tools, but then you show the Create Feature Class wizard (not gp tool).
For geoprocessing tools, use the Environments to control your defaults.  For example, when I set my Output Coordinate System in my gp environments, and then open the Project tool, it looks like this:
Now, for the Create Feature Class wizard, what version of ArcGIS Pro are you using?
In 2.3.1, here is what I see - the wizard picks up the map's coordinate system:
If you're on 2.3.1 and are seeing something different, post back here and we can try to figure out what is happening.
Cheers
