Toggle between next or previous view or pane
287
07-20-2021 05:50 AM
Status: Open
d484648
New Contributor III
Currently you can use Ctrl+Tab to choose a view or pane to activate from a list. It would also be good to have the option to quickly activate the view or pane that's to the immediate left or right of the currently active view or pane in the graphical user interface. "Forward" movement would flow from left to right, top rows to bottom rows (if there are multiple rows); "backward" movement would flow from right to left, bottom rows to top rows.
2 Comments
KoryKramer
So something like 'Alt' that enables KeyTips, but enable KeyTips specifically for Views and Panes (the same that show up in the active pane/view window when holding Ctrl+Tab)?
It looks like Ctrl+F6 will move you forward through the active views, but no option to move in the reverse order: https://pro.arcgis.com/en/pro-app/latest/get-started/arcgis-pro-keyboard-shortcuts.htm#ESRI_SECTION1...
d484648
Yes it would be good to be able to move forward and backward
