Table being cut off from Excel
1486
01-30-2017 01:08 PM
Status: Closed
DerekNeufeld
New Contributor II
I'm using ArcMap 10.4 and when I insert my table (256 rows and 19 columns) it's only inserting maybe 60 rows.  Is there a size limitation to tables?  I am new to ArcMap but it just seems like there will probably be another form of workaround, or I'm doing it wrong.  I went to Insert, Object, and linked it that way.
Thanks for any help
Derek
Tags (1)
4 Comments
PetePedrazzini
Where are you trying to insert a table?
DerekNeufeld
I'm just trying to import it into layout view.
PetePedrazzini
I always had better luck highlighting desired fields in Excel, copy and paste within layout. This seems to work better than Insert, Object. I just tried and copied 738 records from spreadsheet in layout
KoryKramer
Status changed to: Closed
Closing this for ArcMap.  If tables are being cut off in ArcGIS Pro layouts, please contact Technical Support.
Thank you.
