Symbolize - Add all Values: option to base on domain or scan table
100
03-20-2014 12:55 PM
Status: Open
AllanBenvin
New Contributor III
When symbolizing by "Unique Values" in ArcMap, if a domain is present on the column the the values in the domain are added. If there is no domain the table is scanned for unique values in the data.
*If there is a domain but it is out of sync with the actual data only the domain values are added. The other values are listed as "all other values".
We have a large published geodatabase that is replicated from our edit GDB. Although we can repilcate data, syncing domains is much harder due to object locking in ArcSDE.
We have a large user base that occassionally catches that something is missing, at which point we either update the domain or drop it from the published GDB.
I think it would be useful to have a lilttle radiobutton on the Layer Properties - Symbology tab what would allow a user to specify something like "base on domain" or "scan table for values".
1 Comment
DuncanHornby
Just thinking out aloud here. A possible variation on this idea is that the original button stays (as adding more buttons to the already cramped interface isn't going to help) but ArcMap is intelligent enough to realise the field has a domain then offers up the option of domain or scan the table?
