I'd like to see an option to specify which map frame a model outputs to. I have a map with 2 map frames for a specific layout, and I have 2 models to populate those maps with data. Currently I have to click on (activate) MapA and then run Model A, Click on MapB and then run ModelB. I'd like to just specify where the outputs go, string the models together, and drop the layout python formatting in at the end.
