It would be favorable to be able to see two or more coordinates at the same time at the bottom of the map for example both ddm and dms.
Those who works across different arenas (sea and land, civil and military) usually works with different coordinate formats and it would make their work a lot more effective always having all the coordinate formats easy at hand.
The attached picture show how it should look like in Pro.
hi,
I will custumize the map as per the need and show you the map and data on web format as wanted .
Please let me know if needed
Can you explain what you mean? Is it possible to accomplish several display units in Pro today?
