It would be really effective to be able to view, and use the weight-based capacity of the new suitability modeler in a web-based application/widget, but without the need to manually create and share WRO to ArcGIS Enterprise.
What could be imagined is :
- preparation of the criteria data is done in ArcGIS Pro, with value transformations if needed
- data can then be published as a service to ArcGIS Enterprise
- the final analysis, with the relative weight is done in real time in a web application, through a widget or dedicated app. Different scenarios can be applied/saved/loaded etc...
- the resulting suitability map is a hosted layer that can be used in Enterprise for further analysis
- if needed, this suitability map can be loaded in AGPro in order to locate area (which can be resource consuming)
- the web app still give you the ability to perform real time analysis on the suitability map, like charts (based on a selection on the map with drawing/feature as input), zonal statistics (raster with features as inputs or table), reports, ...
regards
