Share as Web Layer - Check for name exists in Analyse
776
06-25-2018 12:03 AM
Status: Closed
DeanHowell1
Occasional Contributor III
It would be good when publishing a layer or layers to Portal for ArcGIS from ArcGIS Pro that the 'Analyze' function checks for the existence of layer names. Currently, if a layer has the same name the Analyze function gives the all clear and it is not until you 'Share' that you get the error.
4 Comments
MichaelVolz
This would be useful to prevent a web layer from being created before it causes downstream issues.
AnthonyRyanEQL
It would great to have the publishing 'Analyze' button check if the name of a hosted feature service already exists in portal as part of that process instead of erroring when trying to publish
JonahLay
Status changed to: Closed
Thank you for submitting this idea. However, we will not be moving forward with this request. Adding an analyzer wouldn't be very helpful. We would still need to check if the service name exists right before publishing.
PaulDavidson1
Jonah, you're missing the point.  Of course you still need to verify the service name doesn't exist before publishing.  The same applies to many Analyze functions.
The point to Analyze is to allow the analyst to catch and fix issues before we try to publish.
