Set layout element Nudge distance
1313
05-02-2022 02:39 PM
Status: Open
CMV_Erik
The instructions for Nudging using arrow keys say the Shift/Ctrl key can be used to nudge 5/.5 points, and this appears to be the case. Sometimes the lowest setting is still too large; it would be helpful to be able to adjust this setting.
My issue that prompted me to post this is that I was trying to make an identical copy of multiple elements in a layout, including text elements. The idea is I wanted to be able to have versions of the same text using different fonts, so they can be turned on and off easily. Only one would appear at any given time.
When I make a copy of the elements, the copy is offset down and to the right. If I try to Nudge the copy to match the original, it doesn't work; the copy is always offset. I will wind up using the textbox setting for the X/Y values as a workaround, but I use nudging in Illustrator so I don't have to do this; it will be great to have the same ability here.
It would certainly be helpful to have the copy's offset be consistent with the nudge. But even better would be the ability to nudge smaller distances, since that would apply in a wider variety of scenarios.
Thanks
3 Comments
Marie_Ducharme
OMG! I totally agree with this suggestion....It's something that would be VERY useful
summerberry
I need this function too!
KoryKramer
Thank you for the comment @Marie_Ducharme   I took a look and it doesn't appear that you added your kudos to the idea. While comments are important, kudos (the number of votes) that an idea receives is one of the primary pieces of data that we use to determine traction and trends as we monitor idea activity over time.
Please see https://community.esri.com/t5/custom/page/page-id/arcgis-ideas for a high level overview of how ArcGIS Ideas works. For more details, see Frequently Asked Questions about ArcGIS Ideas
Thank you for your participation in the community and for helping us prioritize future development efforts for ArcGIS Pro.
