I want to be able to have the same experience I get with ArcMap, I want to be able to right click a Service and see where the backend is located, I want to be able to see whether the service is a Referenced Service or a Service that has been copied to the Server. Furthermore I want to be able to do this from the Portal Pane or View. We need Additional Properties Exposed from the Pull Right in the Portal Pane\View
I second the sentiments of @TedCronin. I am trying to get my staff to use Pro for any/all Portal/Server related functions (Web Map making, layer editing, etc.), but the lack of information you get from the Portal panel makes this transition difficult, so we still wind up swapping between Portal and Server Manager in the web browser and in ArcPro. The same information that I can view in the browser should be available in some way in Pro. The Portal panel has come a long way, but this kind of functionality should be the next focus.
