Save abbreviation dictionaries at the project level, not map level
252
09-23-2022 11:26 AM
Status: Open
wayfaringrob
I just brought a layer over from one map to another and noticed that my labels were no longer abbreviating. I went to re-enable the abbreviation dictionary in the labeling settings and found that despite showing up in the 'Dictionary' box, it was not listed in the dropdown for that box, nor was it listed in the 'Abbreviation Dictionaries' dialog. It seems that these are saved to the map, not the project. It would be useful to have them available project-wide so as to avoid a need to export & import for each individual map on the same project, and to maintain layers' appearance when moving them (at least within a project). It would also help with making modifications to the dictionary easier -- currently, if you want to make a change, you'd need to export and reimport to each map every time.
I suppose saving them at the application level may work as well, but that may be messier than it's worth. Project-level would probably be good enough; maybe when dragging a layer that has an abbreviation dictionary turned on, the dictionary would copy over to the destination project. That would help with inter-project layer dragging and maintaining the dictionary with ease.
2 Comments
jcarlson
Great idea!
I'd like to see abbreviation dictionaries even more accessible than this, even. I know abbreviation dictionaries can be saved to a DB table, but I'd love to see them treated the same way other style / label settings are, save them to a "favorites" list or bring them in from the catalog pane's Style folder.
wayfaringrob
@jcarlson  yeah, something like that would be really nice.
