Retain Metadata when providing a map package to someone outside of your portal
114
4 weeks ago
Status: Open
johnjcarter
My suggestion is to fix an issue with metadata and map packages not retaining the metadata.
Currently when we extracted our Map Package, the metadata is gone when you switch log ins to a new portal or give it to someone that does not have access to your portal, even if you use the Include Enterprise and UNC Path Data option to include all the data. It is fustrating, because you have to switch log in user/portal to publish.
Disappointingly the metadata (summary and description) doesn't come across to the new layers, I would like to see this working even if you do not have access to the portal.
