Retain File Name when Changing File Type in Export Layout
488
04-14-2021 09:48 AM
Status: Open
TimCorner1
New Contributor II
When exporting a layout I use different file types depending on the intended use of the document.  I normally define the file name and location of the layout being exported before thinking about the file type.  When I then go to change the file type, the name and location I just entered in the Name field is deleted.  Replaced by the original file name and location.  I then have to change the file name and location a second time.  Quite infuriating.
Please make it so that when file type is changed in the export layout tool the name field does not change except for the file name extension?
