It would be really cool if you could either insert a new Attribute Rule where you would like it or be able to drag and drop one into a new position.
Currently, you can run the Reorder Attribute Rules tool, but once you run the tool, you have to close ArcGIS Pro and reopen the project to see that change...
Yes this will be helpful.
Also I notice the when we export to CSV there is no column for the order for Calculation Rule
I would like to be able to order Contraint Rules also because we sometimes need to check some constraint before others (some test might depend on other being validated)
This is fundamental to productivity. Please prioritize this above all else!
