Reorder Attribute Rules Interactively
324
02-04-2021 10:38 AM
Status: Open
JoeBorgione
MVP Esteemed Contributor
It would be really cool if you could either insert a new Attribute Rule where you would like it or be able to drag and drop one into a new position.
Currently, you can run the Reorder Attribute Rules tool, but once you run the tool, you have to close ArcGIS Pro and reopen the project to see that change...
1 Comment
SylvainHotte2
Yes this will be helpful.
Also I notice the when we export to CSV there is no column for the order for Calculation Rule
I would like to be able to order Contraint Rules also because we sometimes need to check some constraint before others (some test might depend on other being validated)
