Relationship classes for multiple tables
493
09-28-2011 07:40 PM
Status: Closed
RodneyNielson1
New Contributor III
I have had the requirement to create a relationship class between tables in ArcGIS 10 via the use of an intermediate table, i.e. translating the primary fields within the feature class attribute table and an Access database table which has been imported into a geodatabase, with one to many and many to many relationships. Currently ArcGIS does not allow a relationship class between more than two tables, but if the two tables do not have identical unique identifiers, the relationship is impossible. Access allows relationships between tables using an intermediate table. Similar functionality would be helpful in an ArcGIS geodatabase environment.
1 Comment
SSWoodward
Status changed to: Closed
This idea has been closed as a duplicate of the Data Management Idea linked below. Don't worry, you can still show your support by commenting and adding kudos to the open idea. Thanks for your contributions!
https://community.esri.com/t5/data-management-ideas/relationship-classes-for-multiple-tables/idi-p/9...
