Refresh Domains
4779
23
11-17-2019 06:05 PM
Status: Implemented
MicheleH1_DNReply
I have just finished adding many domains to a new enterprise geodatabase using the Table to Domain tool.  However even after refreshing the database connection when I open the Domain view all the domains I just added do not show up.  I tried removing the database connection and adding it to the project again but with the same result.
It appears the only way to make these domains show in the Domain view is to close ArcPro and open it again.  This seems clumsy.  It would be great if the refresh of a database connection would actually pull back all changes.  It's a pain to have to close ArcPro just to see this sort of thing.
23 Comments
MicheleH1_DNReply
Hey there Kory,
No I didn't have any maps open that were using the domains.  I basically was just doing everything in the catalog pane and then opening the domain view by right clicking on the database connection.  No maps even in the project.  I'm working with an enterprise geodatabase rather than a file geodatabase just in case that matters.
It's weird that it doing it slightly different for you...
KoryKramer
Thanks, Michele.  Tyler Schwartz‌ are you working in an enterprise gdb or file gdb?  Can you share whether you have layers in a map that use the domain being updated?  Thanks.
TylerSchwartz2
File geodatabase.  Yes, the featureclass within the domain file gdb is added and visible in the map (selecting it is how I am navigating to the data>domain ribbon/window).
And to respond to your comment in the other thread, per my testing just now, closing the domain window works on the first time running "table to domain" GP tool (ie: for the first domain added), but running subsequent table to domain GP tools does not reveal the subsequent domains, even after closing and re-opening the domain window. So it appears to only work on the first domain added, but thats it.
Still need to close out of Pro in order to get those subsequent domains to appear.
KoryKramer
OK, we have the issue reopened: BUG-000085913: The Table To Domain tool does not show the new domai..
You can go there and use the Subscribe button for updates.  Sorry for the confusion on this one - it appears that it isn't entirely straightforward.  The team is reassessing this.
Thank you!
ThomasColson
Kory Kramer‌ see my post in EAP on this topic. Seems to be related to
BUG-000115054, BUG-000085913, BUG-000104598, BUG-000116032
HNoakes
Wondering if there has been any progress on this? Should I log a case as we have run into this problem on a project as well.
Heather
CathyWilson2
Just so you know, I am having the same issue in ArcGIS 2.5.1. Created new domains, opened the Domain view, they aren't there. I do have features added to a map, though they are only in the Contents, not actually on the map because there are no records in them yet. I am using a file gdb. The only way I could get them to appear was to close Pro and then open it up again, open the Domain view again and there they are.
NathanHeickLACSD
I want the ability to refresh the domains in the domains tab.  Right now, I am building a new file geodatabase from scratch and I am importing domains using the Table to Domain tool.  However, when I run the tool, the domains do not refresh automatically.  There is no refresh button on the ribbon or a refresh command if you right-click on the view.  I have to close the domains tab completely and reopen it from the Catalog pane.
Sauvelm_KGS
It's 2023, I'm on version ArcPro 3.0 and this problem is still persisting.
note: my original post said 3.1 but actually 3.0
SSWoodward
